So I’ve been drafted into a 60s-esque garage rock combo, half covers, half originals- Our debut show is later this month- Up until last night, I had been playing my beat up (2 broken keys, side panel gone, prog screen dead) Korg MS2000 on its “British organ” patch (when I power it up, I blindly scroll to where I remembered it to be
)- For rehearsal last night, I decided to swap it out for my Voyager OS- Haha! I tuned Osc 3 to a 5th for “chords”, and would flick it off on solos- It definitely changed the character of the songs, but I think in a good way; sort of like the Human League meets the Cramps
The funniest thing is the rest of the band kept calling it an organ, and changed a few of the songs to add “organ” solo breaks ![]()
Anyway, even if the band doesn’t care, at least I would like to get a bit more of a Farfisa type sound happening- before I fire up the laboratory and start tweaking, does anyone have any suggestions? I know my LP had a surprisingly decent “organ” patch, but of course, it being a factory preset, I don’t know how it was achieved…
thanks yall
I made a pretty decent organ patch on my Juno 60 that used the pulse wave, sub osc (so 1 oct down, if you’re not familiar with the 60) and a resonant, tuned filter to add the right harmonic content - if you set the filter to maximum (or near max) resonance, and tune it so the peak is a fifth, or an oct+fifth, above the note you’re playing, and add a touch of distortion, you might be able to get something similar on the Moog. Envelopes should be as flat as pancakes and wide open on the sustain, and you can add a touch of vibrato, but so you might want to sweep the filter cutoff in the same way so as to move the filter peak along with the pitch played.
Although based on the Juno, these may of some use:
http://www.soundonsound.com/sos/nov03/articles/synthsecrets.htm
http://www.soundonsound.com/sos/dec03/articles/synthsecrets.htm
http://www.soundonsound.com/sos/jan04/articles/synthsecrets.htm
http://www.soundonsound.com/sos/feb04/articles/synthsecrets.htm
http://www.soundonsound.com/sos/mar04/articles/synthsecrets.htm
thanks!
so here’s what I’ve got: all 3 on pulse, OSC 2 set up an octave and tuned to a 5th, filter wide open, resonance at 60%, envelopes flat with sustain wide open and 0 release- I also added a little bit of noise and Y-cabled the effects insert back into the external input jack (and cranked it up) for dirt, and sent pitch vibrato to aftertouch- hitting the Osc sync switch for leads sounds good to eliminate the 5th without losing meat-
sounds great here at home on my PA- I can’t wait to try it through my old nasty Fender twin with the rest of the band blaring! hopefully it won’t be too trebly, but I can always kill the brightness switch on the amp…
thanks for the suggestions, and if anyone else has tried something like this, I’m all ears!
Well I tried it out with the band, and WOW! Spot on!!
I know some may e-smirk and say “if you want a Farfisa sound, why not get a Farfisa”- Well, I’ve used a Farfisa before in a similar setup, and it was hard to get it to cut through the loudness of the rest of the band without being shrill- And even then, different registers would either be painfully loud or lost in the mix- The MS2000 was OK, but would still get washed out by those dang guitars- The Moog? Ha! Even cloaked by the filter on the mellower tunes, every note and nuance was THERE- The only problem I had was my occasional clams were not lost- haha-
I have a Farfisa. I tried to fix it. Sometimes it works, sometimes it doesn’t. I think the 400+ caps need replacing. DO NOT get a Farfisa, unless it has been completely overhauled, unless you plan on using it as a workbench. Plus, they’re heavy. ![]()
haha! yeah, the one I used for a bit wasn’t mine- another friend of mine recently got one via Ebay that she had to get overhauled- our local synth/guitar/anything tech spent 3 months on it, finally finished it, and told her, “spread the word, ‘I WON’T work on Farfisas!’” ![]()
I love working on mine…it makes a great soldering station. ![]()
If you truly sound like the Cramps meets Human League,I’ll buy your music!
R.I.P. Lux Interior.
we’ll see how it translates in recording, but it does sound pretty wild live! although, since my magic patch, it sounds a bit more 60s vs 80s- maybe I’ll sneak it a bit of glide to at least bring it more toward the 70s ![]()
I’m glad to hear someone’s still playin’ the devil’s music!
Other one over here ![]()
I’m working on it.It’s gonna be a while until the noise I make could be considered music!
Yeah, this fists my other projects: music that even the devil is not very sure to plainly understand ![]()
