Modulation destination difficulties
I have a problem with my modulation destinations on my signature voyager. The destinations do not match up to where they are supposed to go. For example when i select the modualtion wheel destination as FILTER instead it gives me OSC2. It also gives me PITCH as the destination when it should give me OSC3
This is only on the modulation wheel bus, the pedal/on bus works fine.
Any ideas/suggestions to fix this?
Strange.
Is this a new problem?
i think i saw it before with just the FILTER dest being OSC2dest, but i just presumed it had been set up like that in the starting patch. So i can’t be certain
Sounds to me like you have something funky going on with the demux IC on the mod wheel buss. Signature Voyagers have a four year warranty, I’d run this by Moog Music.
I was advised by moog to update the software version. I was running 2.0, i now have 2.5 but it hasn’t chaged my mod bus back to normal.
ANY IDEAS???
I am in the UK, just hoping i’m not gonna have to be sending across the atlantic!!!
