hello..
quick question…
sub 37
i can’t seem to modulate the filter slope from either lfo mod bus..
bus 1 withe modwheel up at 100
bus 2 with after touch..
both src’s are on pgm…
any ideas?
many thanks.
hello..
quick question…
sub 37
any ideas?
many thanks.
Assuming everything else is set correctly…If the preset in question is saved with the 24db slope, then the mod depth needs to be negative. So the setting will modulate to the left. If the slope is set to 6db the mod depth needs to be positive. So the setting will modulate to the right. This had me stumped for a minute as well. Seems like that parameter doesn’t go around in a loop, it changes by moving to the right or left only. (Positive or Negative)
Hope this helps.
lovely!
thank you!
