Model D Reissue tuning issue
Hi all.
Is it normal that the Model D Reissue looses the tuning along the scale (don’t remember how that is defined, but you get 1 octave to be “almost” in tune, the octaves above/below are not)…
Any reports/feedbacks on this?
F.
Should not happen. Even after a longer period of months not used. No problems here. I would check the PSU first.
You’ve probably sorted this by now, but it sounds like it needs recalibrating - the procedure is described in the manual if I remember correctly.
