Model D (reissue) road case?
Hello!
Quick question. Will the Model D reissue fit perfectly in a case made for the classic? The dimensions should be exactly the same right? Anyone knows?
Thanks,
Peter
Dimensions for the new model D are on the MoogMusic.com website.
Yes, but will it fit in a case made for the classic model D? Which is what i assume most Model D cases currently available from case manufacturers are modeled after?
Found this on the web from a newsgroup post in 2005:
OVERALL SIZE (with Front Panel down):
28 1/4" wide, 16" deep, 5 1/2" high
NET WEIGHT 28 lbs.
You can compare that to the new Minimoog’s dimensions at Moogmusic.com
Hope that helps, Mark
OK, not the same dimensions then, if those numbers are correct.
For anyone interested. I just got word from Moog customer support that the dimensions of the classic and the reissue are indeed the same.
