Model D app Bank MSB LSB
Hi all!
What are the Bank Select MSB and LSB values for the Model D app presets?
Do user presets have a specific bank select value?
Thank you!
Sam in NJ USA
MSB is set with CC00, and LSB is set with CC32. You get the Bank number with the formula: BANK = MSB (CC00) * 128 + LSB (CC32). In most cases, MSB is not used, as the LSB value already gives access to 128 banks. This is what is used in Ableton Live (Bank = MSB | Sub = LSB) and some Midi Controllers may use the same Control Changes (CC00 + CC32) to assign bank. Last, please note that it is only when LSB (CC32) is sent a value, that a bank is loaded. Changing MSB (CC00), only stores a value until LSB is assigned.
Thank you Gil.
If my custom patches are in Classic 17 and Lead 29
What are the corresponding bank MSB and LSB for each user patch?
Sam
MSB 0 ignored, LSB 32s are
0 bass
1 classics
2 effects
3 keys
4 lead
5 pads
6 perc
Sam
