mod wheel trouble
hi. i bought the little phatty ed 1 (upgraded to vers 2.0 530) a few weeks ago. after a while the mod wheel wasn’t working as it should, it started working more similiar to the pitch wheel, i think the problem is that lfo rate doesn’t answer. last time i just did a factory restore and then it worked fine again but now it has happened again and i don’t wanna do the restore this time, i want to know what is wrong instead.
can anybody help me?
Josef
I’m sorry to hear that! Have you tried restoring your LP to it’s original settings? make sure to back up your patch library first.
check the LFO SYNC page (master menu); maybe it’s set to MIDI CLOCK and you are not sending a MIDI clock?
Set LFO SYNC Mode to “INTERNAL” or send a MIDI clock to your LP… maybe it will help.
