Mod to Fix the High Freq Roll-off of the MF-101 LPF
It was brought to my attention that the MF-101 Low Pass Filter has a roll-off of high frequencies, even with the filter opened up all the way or when in bypass mode (note: the MF-101 does not have true bypass, the Drive circuit still affects the signal in bypass mode). I tested my MF-101 and confirmed that there is a slight but audible cut of high frequencies. I had used a workaround for a while (a parametric EQ to boost the input signal highs to compensate), but I decided to find and fix the problem in the MF-101. I found that there is a low pass filter built into the audio signal output buffer. Removing C21, located near U1 in the upper left corner of the PCB, restored the high frequency response.
Obviously, this low pass filter was added for a reason. My guess is that it was to help tame the high frequencies that the MF-101 can produce when the resonance is turned up until MF-101 oscillates. If you decide to make this modification, be extra careful and heed these warnings from the manual:
I wasn’t aware that the 101 had this problem. A few other dudes, myself included, have this problem with the 107. Care to take a stab at that?
Sorry, I don’t have one (yet!), so I can’t help with that. I read the topic about that last weekend and that inspired me to finally find what was causing the problem with my MF-101.
The MF-101 roll-off is very slight. Since this box does not have true bypass, you wont notice the roll-off by just switching between bypass and Mix knob at zero. The easiest way to hear the roll-off effect is to compare the original audio signal with the box output in bypass mode.
:blush: : edit: sorry I have to stop reading posts as I’m going to bed. Cuz I don’t read the correctly or all the way through
