Mod souce and dest in editor
May be a dumb question, but here goes:
In the sub 37 editor - where can I see the programmable Mod sources and destinations?
For example if I want to set aftertouch to modulate filter cut-off - is there a way to do that simply in the editor?
To see the programmable Mod sources and destinations:
  • Select EDITOR in the upper left PAGE selector. The PGM SRC and PGM DEST can then be found in the LFO 1 and LFO 2 sections in the lower part of the screen.
For aftertouch to modulate filter cut-off:
In the LFO 1 section:
  • Set PGM SRC to CONST ON
  • Set the AT slider to maximum (also ensure that the MW and VEL sliders are set to minimum)
In the MOD 1 section:
  • Set MOD 1 SOURCE to F.EG/PGM
  • Turn FILTER AMT fully clockwise (or to the desired modulation range)
