Here is a question…how do the MSB/LSB continuous controllers that are sent by the MMV get mapped? EG, when you turn the filter cutoff knob, it sends controllers 19 & 51…how do the values vary (EG, when using filter cutoff to control cutoff in Arturia’s Minimoog V, you can have a coarse and fine controller mapped; I’ve used controller 19 as coarse, but the controller 51 doesn’t seem to be very logical. I’ve ended up using Cycling74 Max to run an a LSB filter which I pass via MidiYoke to Sonar/Reason…clunky!)
Is there a way to add a menu option (like the CC reduction of the mod wheel) so that the voyager could be better used as a master controller? (EG, when using Reason or Arturia Minimoog, send only controller 19 when filter cutoff knob is turned?)
Patrick T. Rost (psound74)
