Mixing an album. Problems with Animoog please help!
The new version includes enhancements to pressure modulation behavior. I always use an external keyboard and when I started to record my Animoog sounds prior to doing the final mixes, I found that all the sound were different. I finally figured out that the sound I use can only be achieved if you play the application’s keyboard, touching each note at the top (full modulation I guess). The sound from my keyboard matches the sound when played in the app, at the bottom of the key. Is there any way to disable this modulation control? If not, is there any way to go to a previous version of the application? This is a nightmare. I cannot continue the mixing sessions!!!
I’ve been having this same problem!! Have you figured out how to fix it yet?
