Missing files in "Factory Presets"
I’m not sure how much it matters, but there’s a few presets missing from the Factory Presets folder and the Factory Presets.zip file (for 0.9.37).
They are:
  • Gravity: Reversed
    DI^tOR~ED BRA/S
    SYNC/SNARE
Actually, there is an empty file called Gravity in both the directory and the zip file, presumably from Gravity:Reversed. It’s easy to see how special characters in the name can conflict with the file-system needs.
Nothing very important; maybe something to tweak when everything else is done. :slight_smile:
Thanks,
This should be fixed for 0.9.40, once uploaded will you be able to verify ?
Looking in the “Factory Presets” folder we see …
 1.01 brass      'DI^tOR~ED BRA/S'      'DItOR~ED   BRAS.syx'
 1.01 duo        'Gravity: Reversed'    'Gravity    Reversed.syx'
 1.01 sync       'SYNC/SNARE'           'SYNCSNARE.syx'
Looks great!
However, the included ZIP file is an older one, which has the empty Gravity, and is missing the other two (distorted brass and sync/snare).
 $ ls -l Factory\ Presets.zip
 -rw-rw-rw-  1 first1  admin  99110 Feb  5 01:22 Factory Presets.zip
Maybe just leave it out…
