Just wondering if its possible to do the pitch wheel trick on the minitaur, where you hold the wheel all the way up and can access another octave higher?
If I’m not mistaken, you can go 2 octaves in range via Minitaur editor on any particular patch. But the upper reach of the OSCs are fixed regardless of pitch bend or tuning.
The oscillators themselves are limited to C5 maximum, editor or not. That being said, you can track the filter up as high on the scale as you want. You can make a filter track the pitch 50%, 100% or 200% and play melodies in the upper register, while keeping the oscillator voices turned down. If you feel like making some sort of grinding tones and using the oscillators with the filter, you can play lower than C5, so the oscillators track AND the filter tracks. Just tune the filter cutoff until it gets to the note you want.
I’m sorry, I was simply replying to the comment about pitch bend being ‘limited to 3 semitones’ (paraphrasing).
And suggested that within the Minitaur editor that you could change the bend range as high as 24 half steps (2 octaves) but unfortunately, the OSC will run out of range regardless of this setting. Voltor’s note about getting the filter to self oscillate and subsequently output sine wave is a good one provided that you can get it to scale properly (and of course, you’'ll need an external filter in order to further sculpt the sound).
