Minitaur problems
Hello everyone, I’m new on this forum.
I bought a used Moog Minitaur a few time ago and I have the following problems:
  • The CutOff does not work, nothing happens when I turn it.
  • I can not save my own presets on the Minitaur. When I load a preset with the editor that is not saved identically on the Minitaur.
  • I do not have midi signal when I plug the Minitaur has a master keyboard with a midi cable but it works via USB.
  • There is also a problem of false contact at the input of the power supply.
Do you think all these failures may come from a firmware problem ? they have a connection? The synth is in Rev2.
The Minitaur is out of warranty and I live in France (excuse my English), so I can not return the Minitaur for a factory repair…
It sounds like the unit may be in a strange mode w/ Local Knobs turned off.
Regardless, you will want to download the latest firmware version and install it.
http://www.moogmusic.com/products/taurus/minitaur#downloads-tab
If this doesn’t work, please email support@moogmusic.com and we will help you from there.
-Your Friends at Moog
