Minitaur preset change in Ableton?
Hi all
New to the forum. Seeing lots of messages from you all regarding difficulty between Ableton and the Minitaur plugin!
I’m working on a Mac with Ableton 9 Suite.
I’m trying to automate changes between presets I have saved in the MInitaur preset manager… so start with ‘my preset 01’ and automatically move to ‘my preset 02’ when I change Ableton scene.
Is that possible? I can’t see an option to do it.
Thanks for your advice!
When you double clic on a clip, down in the Clip View you are able to select you patch on the Notes section, right down where it says Pgm Change. If you select a different Pgm for each Clip, it should change the preset of the Minitaur accordingly with each Scene
