Hi guys!
I got a Minitaur recently, and I’m using it with Ableton 9 connected with USB to a Mac.
I have the Minitaur set up as an External Instrument, just like in Amos’ video.
However, I’m encountering a problem with the Minitaur always playing double notes.
In the External Instrument settings, if I setup the Audio From parameter to No Input, there aren’t any double notes, however, as soon as I choose an audio input, the double notes appear.
I’ve tried sending a Local Control Off signal like suggested in this forum as well as in the Ableton manual, to no avail.
I’ve been sending the Off signal through Max for Live devices and MIDI controllers. I tried sending the signal through the USB connection, as well as directly connecting the Minitaur with a MIDI cable to a controller.
I’m able to change other MIDI parameters through both connection methods, so there definitely is a signal going through to the Minitaur.
Any ideas as to what might be the problem? Maybe I did manage to switch off Local Control, but there’s something else that could be causing the double notes to be heard?
Any help would be greatly appreciated, as I’ve been spending hours on this problem for the past week, and honestly I’m very disappointed in the Minitaur right now. The sound is great, but it’s completely unusable.
Mike
