Minitaur not midi chasing CC correctly
Hello,
I’m having an issue with the Minitaur not chasing midi CC correctly. I’ve recorded a midi cc message to turn off release in my DAW. If I start playback in my DAW sequence before the midi CC message, it starts with the release on (button glowing) and once it turns off once it plays the Midi CC72 node at a value of 0. However if I then stop my sequence, the release button is back to glowing, and if I were to then continue from this point the release function is back on! SO something is wrong with midi CC not chasing correctly.
In Cubase I have the preferences set to chase all midi CC events, and in all my virtual instruments this is the case and it chases all midi CC. The Minitaur is my first external synth so I dont know if this is a common flaw in external synths, or perhaps I’m missing a setting on the Minitaur? But as it stands now I cannot use this in my composition work as I need it to properly chance midi CC events.
Hopefully a smart and kind soul can help me.
I figured out the issue. Because I’m using patch changes, I recorded the patch change as midi CC in my daw, which because its midi CC its chasing it back to the original preset settings every time I start playback! So now I need to figure out how to do patch changes without midi CC. Is this possible?
Ok I found a solution. In cubase I can make it so program change messages dont chase, so now all the midi CC’s I change are chasing except the patch changes. This might cause an issue if I have many patch changes in a song and start playback without first playing the program change node, but so far this is working!
