I know we’re in the analog domain but my volume pot is really noisy.
Impossible to make a nice volume fade in.
Anyone else has experienced this ?
Thks for your help.
Greg
try changing the value of the Attack on the Amplifier section before you press a note on your keyboard, that should give you a nice fade in
Thks for the tip bichuelo but sometimes, especially in live situation you just have/want to play with the volume not the envelope.
In this case, my minitaur is a no go, it really makes some audible scratchy noises as I turn the volume knob up/down.
Just want to know wether mine has a problem, is yours doing the same (or anyone else) ?
Thks for your help.
I never heard any glitches while moving the master volume.
Thks greenborder.
That’s what I thought, not normal, my minitaur has a problem.
Tough luck mate, hope it can be taken care of - otherwise you might want to connect it to a mixer and do the fading from there?
Helly Mydni,
I actually have the same issue now, it’s a new thing, I don’t remember having this before…
Did you sort that out?
Cherio
late to the dance, but mine has started doing it also.
Check and make sure your controller is not sending CC#7 as you are adjusting the volume pot, this can cause symptoms that seem a LOT like a bad pot.
Hi there,
As I was saying, I got mine serviced. Here is what the rep says about what we done to it:
“replaced a potentiometer and re-glued ribbon”
Now works like a charm…
Cheers
I had the same issue, and was fooled because the headphone output didn’t seem to be making a noise when the pot was moved. I emailed Moog and received a prompt comprehensive reply from Adam. He recommended applying the contact cleaner anyway, and in 45 seconds my Minitaur was producing a marvelous clean output with smooth volume response. Hooray!
Long Live Moog!
Bruce
Hi all,
Think I’m suffering a similar problem. Noisy pot, but also I’m getting quite a lot of noise on top of each note I play.. ok well note a huge amount of noise but I’m sure it’s not normal.
I made a quick recording
https://soundcloud.com/richard-lodge/moog-minitaur-test/s-xZYJ2
You can specially hear as the longer notes fade away.
Do you guys think a bit of contact cleaner would help (is so applied where?) or should I get it serviced?
Richard
Hey, i have been experiencing the noisy volume pot myself in a while, any advice will be appreciated. I’ve made a quick recording: https://soundcloud.com/danioan/minitaur2 - this is with a note playing and this https://soundcloud.com/danioan/minitaur is only with the pot turning.
i am very concerned as the Minitaur is my main bass synth ![]()
