hi all guys. Can somebody please help me step by step how configure analog four with moog minitaur or moog minitaur with analog four via CV / GATE ? i can´t get any pitch. I have more cv synthesizers and they dont give problems, all except minitaur. I installed the latest firmware and have followed some instructions in other forums but no good results. its a nightmare, i use the calibration cv tool in the editor but its impossible to fix this problem.
i have note 1 > “c2” 1.000volts note 2 > “c5” > 4.000 volts pitch/oct
thanks and sorry for disturb.
Minitaur Pitch CV Calibration Procedure
Connect the voltage source to the Minitaur’s pitch CV input.
Now connect the Minitaur to your computer via USB and open the Minitaur Editor.
In the editor settings, locate the 1 volt and 4 volt calibration options.
Send 1 volt signal from your voltage source into the Minitaur, then click the Pitch CV Calibration +1v button. You will see the MIDI light on the Minitaur blink.
Send 4 volt signal from your voltage source into the Minitaur, then click the Pitch CV Calibration +4v button. You will see the MIDI light on the Minitaur blink.
This ends the pitch CV calibration procedure. Please test with a 0-5v CV source.
If this does not correct the issue, please contact us directly and we will be more than happy to help.
Adam Pryor
adam@moogmusic.com
(828) 251-0090 Ext. 246
Harrison Street
harrison@moogmusic.com
Ext. 221
Noah Jolly
noah@moogmusic.com
Ext. 204
Thank you,
Taylor Mott
Service Manager
taylor@moogmusic.com
Ext. 217
thanks but it doesnt works .
