Minitaur Midi bugs x 2
Bug 1
Minitaur has same bug as MF-108M when syncing to midi clock for LFO sync
Here is workaround from tech support
We suggest unplugging the MIDI connections all together with your MIDI clock device off, power up the MF-108 M, hook up the MIDI and then power your MIDI clock device. We seem to have success getting the MIDI synced this way every time.
Bug 2
Also another bug with Mintuar is depending on how you power up Minituar will only regonise midi note gate over USB --not midi note pitch
Fix is too unplug power cable from Minituar for 10 seconds and then power Minituar back up
cheers David
Interesting! Thanks for the report, I will look into this ASAP
