Hello all.
How to do a sysex dump from Minitaur?
thanks
I am afraid the is no documentation of this available.
But listen to the MIDI stream going from the editor to the Minitaur to get the command. Then reverse engineer what value of the response is doing what. And then learn how to send the data back to the Minitaur by learning the meaning of the stream going to the Minitaur when calling a patch using the editor.
Or you may just use the very user friendly user interface of the editor for doing all the sound keeping.
Thanks Till. You are right, the editor interface is friendly and it works fine but I wanted to use the ipad to store patch.
thanks again and sorry for my bad english
Hi -
There is a SysEx command that will cause the MT to send the current state of all of its settings in MIDI CC messages.
F0 04 08 1B 00 00 F7
This should work in v1.0.7 which is our current version of firmware. In older versions the switches may not transmit correct values.
Contact tech support if you need to update your unit.
Hope this helps
SD
I can find only the editor and the manual.
By the way, where is the firmware to download?
For the latest firmware contact Moog Music tech support.
techsupport@moogmusic.com
When we finally release the Editor officially, the latest firmware will be public on the website as well.
SD
thx. Somebody linked me to this:
http://forum.moogmusic.com/viewtopic.php?f=11&t=13852&start=15
hope moog will implement a permanent official Link
