I am also suffering woes with the Minitaur and Windows 8/Ableton Live compatability.
I have researched every available internet resource, read the manual and all readme’s that you have supplied, updated my firmware and attempted to install the usb midi driver (failed - same error as everyone else).
I went and bought a usb to midi cable/interface, after many hours of trial and error I have the Minitaur functioning in Ableton with windows 8, well 1/4 functioning and it crashes my projects constantly.
MOOG
Am I right in assuming that the only way to edit the completely necessary editor functions (such as LFO retrigger, glide modes) is to disable the Minitaur in Abletons midi preferences, then enable the USB To Midi device (a usb to midi cable converter I bought). Then create external instrument, send the midi of that instrument to the USB MIDI device. Then with the Minitaur plugged into the computer via windows usb the plugin will open and show firmware connected when placed on that external instrument channel, respond to paremetre changes and play sounds from another midi device (in my case Push).
Ok so far so good, when it doesn’t crash ableton or disconnect for no reason (requiring Moog restart or computer restart to fix) all of the above functions work.
This brings me to 1/4 functionality with this setup, which is the only documented setup that works.
When I enable Sync on my USB Midi interface Device in the Ableton preferences, upon playing the session it sends a steam of midi data to the Minitaur, making any notes played stick and generally glitch it out.
So there is NO SYNC FUNCTIONALITY as it must be disabled for playability.
Also, because the Minitaur is only receiving midi from the usb midi device and you cannot enable the Minitaur in Abletons preferences or the interface won’t work, this means that there is
NO WAY TO RECORD MIDI AUTOMATION, as there are no ‘working’ inputs in this setup.
Also when the plugin is functioning and connected, it only takes around 10 minutes of playing, or even a few pluginside parametre changes and it either disconnects, crashes my session or completely freaks out and starts making new tones etc.
No my moog is not faulty, Windows and your plugin is faulty.
If there is currently a working way to use the Minitaur with ALL advertised functionality in WINDOWS 8 please enlighten me. This means I can edit the hidden functions (which are necessary imo), record or draw in automation and play back midi from clips and also play live from another Ableton device (such as push or any usb midi device).
I claim false advertising.
I love the synth, I want to use the synth, let me use the synth Moog.
I bought analogue to make my workflow more efficient, didn’t expect to be in for half a week of troubleshooting.
Hate to say it but at least the Microbrute does everything out of the box and works flawlessly without confusion.
