I asked this question: Independent of the menu the changes of answers of the filter are made by the controls in the panel of Voyager through the controls SPACING and CUT OFF?
thanks
Hello,
Yes, the panel controls allow you to select Hipass, Lowass (or bandpass)
as your filter passband modes. In dual lowpass mode, the cutoff ctrl varies the center frequency of both filters, spacing is an offset between the two.
In hipass/lowpass mode the filters indirectly form a bandpass filter , with the spacing control setting the bandwidth. In this same mode, you can get a single-filter hipass or lowpass mode depending on which output jack is used. This, including resonance can all be set from the front panel controls however, these parameters are different from the cutoff slope functions. The slope functions determine the level of signal attenuation beyond the cutoff frequency, and can be set independently for each filter. These slope settings for each filter can only be selected via the Vger’s software.
Regards,
LWG
did you know that there is room for more than two posts in each thread?
