Hello! I am new to this group and I’ve just purchased an early Minimoog via ebay and wondered what the operating voltage was? Will I be able to plug it straight into the 240v supply here in the UK or will I need a step-down transformer to convert the supply to 110v first?
I used to own a Prodigy and that operated on any supply between 110-240v.
Well it’s an original US model but it’s coming from France. It hasn’t been modified in any way, I know that, so that shouldn’t make a difference. Is the Mini the same as the Prodigy in that it’ll accept all voltages from 110-240?
I seem to recall the Prodigy had this info on the back panel but I don’t know if a Mini does or not.
Most model D minimoogs have a 120/240 volt selector switch on the rear panel. However the earliest ones did not have a switch, but these would be the first few hundred. Seeing that over 12,000 models Ds were built then your chances are good.
