minimoog model d’s S-trigger with keystep
Does anyone use the vintage minimoog model d and keystep by connecting it with s-trig? There is no sound when I play the note in the keystep
Is the Keystep able to send S-Trigger (actually a gate to ground)?
Most synths use a voltage trigger. And most analog interfacing of todays sequencers don‘t offer the needed S-Trigger.
There are converter available. It takes just two resistors and a transistor to do a converter.
I think the Keystep gate out needs to be set to STrig whIch is what the Moog requires to fire the EGs. Manual at 10.9.4.3. You will also need a mini-phone to synch jones cable. YOu can make one, or DotCom sells a 1/4" to synch jones https://synthesizers.com/qmvs.html which you could use with a 1/4" F to miniphone M adaptor.
