Hi @ all,
I remeber, that I´ve read years a go, it´s possible to use the Polypedals from the Polymoog with the Minimoog Model D too to control volume, filter etc. Is it true?
Regards, Mario
Nope. Polypedals require a +5VDC power rail on pin 5 of the cinch-jones accessory plug, the minimoog does not supply this rail.
Thanks for your quick answer. Mario
You CAN use the sustain pedals for Glide or Decay on the Mini though.
No power needed.
Just wondering if the Polypedal could be used with a Moog modular. The 910 power supply has three cinch jones accessory plugs with 3 prong outs and the middle prong supplying +5VDC volts. An adapter cable would have to be constructed CJ female 6 Pin to CJ male 3 Pin. A breakout box could be utilized to separate the large cord bundle and bring necessary outputs to the front, mainly volume(swell), filter and pitch.
