Can anyone describe the key height adjustment procedure to me. I have one keys that needs a little adjustment.
Pics would be nice ![]()
Thanks in advance,
Harry
Thanks in advance,
Harry
I forgot to mention that I do not have the special tool that is needed/suggested for this procedure.
Also, the key is a little higher than the rest.
Is the bushing ok on that key? Does the key click or make noise either on the up or down-stroke? Also, the little metal “fingers” that stick out under each key that holds the bushings could probably be adjusted down slightly–but be careful! Although they are made of fairly stiff metal they can break off if treated too carelessly or accidentally hit too hard. I’m sure someone more expert than I may chime in here.
