I have bought the s-trig cable and MOTU Volta,
I have a MOTU 2408mkIII and Logic 8 pro
but it looks like Volta only triggers the last note I played on the Minimoog keyboard.
Anybody has Volta and a Minimoog D with Logic?
Thank you
Sergino
I don’t know anything about Volta or Logic, but have some grasp of Minimoogs.
Unless your Mini is modified to accept a CV and Gate or S-trig, you’ll likely experience problems.
Plugging into the OSC IN jack on a Mini will only add to the keyboard CV.
But the keyboard CV is held by a memory circuit (sample and hold) when there’s no key held down.
And if you hold a key down, the ext S-TRIG won’t work because that held-down key is producing a gate too.
So generally one has to get their Mini modified to accept ext signals.
And if you’re in there modifying it, you can just as easily wire it up to accept standard gate (V-trig) and not need an S-trig cable at all.
A Mini operates internally on positive gate (V-trig) signals, not S-trigs.
Good luck! ![]()
