minimoog D noise on filter?
Quick question.. Should i be able to hear white noise on filter modulation with noise switched off? got a Model D. Definitely hearing a white noise hiss on the filter and the only way i can get rid of it it to hang the noise switch in a position between white and pink.. that can’t be right, can it?
Thanks.
Sounds like your noise switch is… noisy
No, thats not o.k. If "Noise" is completely turned off, you shouldnt hear any noise in no way anywhere.
MC will be right, very likely.
