Midi volume level problem
Hi! First post here… just picked up a littly phatty stage one today! I’ve been playing with it almost all day as you can imagine :astonished:
I have run into a problem when using it with my DAW though… I’m running FL Studio 10 with a M-audio Fast Track Pro.
The problem I actually have is regarding midi patterns. I have connected the MIDI just fine, and I can sequence something within FL Studio and it triggers the little phatty just fine… But when I press stop on the DAW, the Volume level of the phatty goes WAY up. Then when I press play, it plays at that high level, and then when I put even the slightest turn on the little phatty’s volume knob the volume jumps back down to where the volume knob is indicated.
Any clues as to what’s going on?
I had similar issues with cubase.
The DAW is tramsitting CC messages that trigger changes in the Phatty.
You need to somehow disable it in the DAW.
