I’m using the Genome midi sequencer on the iPad.
Connected to the Slim Phatty via the camera connection kit (USB).
Channel 1’s sequence is triggering the Phatty - no problems triggering is fine.
Genome is sending a midi drum sequence on channel 10, the midi (DIN) of the phatty is connected to an SPD-20.
Nothing seems to be going through the midi through at all - have plugged it into ableton and registers no MIDI being sent - but does register if I move knobs on the phatty. edit - registers from the MIDI out not thru.
When I use the DIN MIDI input on the phatty the DIN MIDI THRU does send.
Is there something that I have to set to be able to use the USB in and send via the DIN thru?
edit - I have also run out from Ableton to the SP - also doesn’t send thru via the USB - but does via the DIN .MIDI IN
