I upgraded to OS 2.1 a few weeks ago, and now my midi playback won’t work!!! I get only one note every so often. . .anyone else having this issue. I plan on upgrading to OS 2.4 tonight. We’ll see if that makes any difference.
From the OS v2.1 manual
- MASTER menu button
4.2 MIDI Key Order
The MIDI Key Order function allows multiple Voyagers to function together as a polyphonic synth. Up to 16 Voyagers can be Linked together to create a 16 voice synth. The Value of the MIDI Key Order Number assigns the Voyager to one of 16 voices on the MIDI input. To use this function, select “MIDI Key Order” and press ENTER. The screen will prompt: “MIDI In Key Order is not active” Use the +/- Buttons to select if this is not active, or 1-16 and confirm by pressing ENTER. If you are using a single Voyager – make sure this feature is not active, especially if using with a MIDI sequencer.
That was it. Thanks. I feel a bit silly for not fully reading the manual, but thanks for responding!
where can i find v2.4 and what is different/new?
cb
Does anyone really own 16 voyagers. That would be pretty neat to have a 16 voice Mini BUT?
From Florida - IVAN!!! Two have been enough.
