when i go to record lp stage ii into midi notes the midi notes are written all over the place even when not touching the lp. i know its not a problem with the daws as i tried in ableton and logic and had the same results. could it be a firmware problem or what? the midi notes aren’t even playing the audio pattern.
What happens if you take out the midi-in cable from your phatty?
Still the same problem?
I rebooted the lp and it was fine after that. thanks for the help though.
