MIDI control of the LP
I have scoured the manuals, hoping to find a way to change preset and turn on/off the arpeggiator via MIDI. Is there no way to do this?
Thanks.
I don’t think so. I vaguely remember this feature being brought up for an update, but that was a long time ago. Maybe it will be available with a future upgrade? :confused:
thatwould be helpful in my situation… :cry:
This will be implemented in the next firmware update!
actually you can change preset now, using a MIDI program change command. It’s pretty standard stuff.
Midi CC#90 will be arpeggiator run/stop.
All the arpeggiator parameters (and the other Advanced Preset options) will get Midi CC control soon…
-Amos
Hey Amos,
How soon are we talking here for the next LP firmware update? Just curious. I wanna be able to turn the arp on/off with my MP-201! I’m going on tour soon and this would be huge :wink: !
waide
myspace.com/goodluckatthegunfight
Have you upgraded to the latest LP OS?
Here are the new features:
New MIDI controls – the Arpeggiator now sends and receives new MIDI CC messages
as follows: CC 90 = Arpeggiator Run/Stop; CC 91 = Latch On/Off. The Arpeggiator
internal tempo can now be set by MIDI, using a pair of messages on CC 4 and CC 36.
  • CC 4 sets the Arpeggiator tempo in increments of 3 whole BPM, from 21 to 318 BPM.
  • CC 36 increases the current tempo by increments of 0.1 BPM, from +0 to +12.7 BPM.
    The actual Arpeggiator tempo is calculated as [CC4 value x 3] + [CC36 value x 0.1].
    The LP sends CC4 and CC36 whenever the user changes the Arp rate from the panel.
    ● Improved Tempo accuracy for Arpeggiator Internal Clock and MIDI Sync.
    ● Tap Tempo now averages over multiple taps, making it easier to match a live tempo.
    ● Improved Auto Tune mode, enhances accuracy of background tuning.
    ● Updates to Arpeggiator user interface:
  • If the Arp clock source = Internal, user can adjust tempo in 0.1 BPM increments using
    the Value knob. Cursor automatically moves to BPM field when Arpeggiator is running.
  • User can save a preset to memory while the Arp is running; just press CURSOR
    button to move cursor into Preset Name field, then press Enter.
  • If Arpeggiator Clock Source = MIDI or LFO, this is displayed on the LCD screen.
    When Arp Clock Source = MIDI, a MIDI clock must be present for the Arpeggiator to
    run. If no MIDI clock is detected, this is displayed on the LCD screen.
    ● New preset format, allows “Patch Category” to be assigned using the Little Phatty
    Editor Librarian software.
