Hello
I recently updated my LittlePhatty Stage II to the new firmware v3.1 because I was not able to get the MidiClock-Signal into the LFO-Section with version 2.2. The arpeggiator responded correctly on the midi clock signal. I hoped that this might be a firmware issue. But seems like it wasn’t, now even the arpeggiator doesn’t sync to the midi clock (I switched from Internal Clock to MIDI Clock and now the arpeggiator doesn’t work at all, no more sound is coming from LP when pressing the keys…).
LFO: After switching Clock source from INTERNAL to Midi, the LFO doesn’t change at all. It’s still possible to alter the speed of the LFO - even if there it should be setup to scale up to 1/16 of the midi-clock. I thought after activating midi clock, it shouldn’t be possible to alter the LFO speed at all, but it’s still possible on my device - with version 3.1 and 2.2 too.
I usually send MidiClock Signals from Cubase 6 through my Motu 828 MKII Interface (MIDI OUT) to a Midi Switch (One In, 4 OUT). I just use the Midi clock, no other MIDI-Signals for my setup.
Additionally, I tried to attach LP directly to my MC-303, didn’t help much. The Midi-clock is proper, it’s possible to clock the other devices as the ALESIS Micron and Roland GAJA and the KAOSS PAD3.
And I don’t think that it’s a hardware port problem, because with Version 2.2 it was possible to get the ARP running on the MIDI Clock.
Did i miss something important?
Thank you very much!
stromflut
