MIDI Clicks
When sending and receiving midi info the sub 37 is getting clicks and audio artifacts. Would anyone know if maybe it’s my interface? I don’t have another interface to test but I was wondering if anyone else has this issue.
update
I have tried using midi over USB and the standard midi cables. Both produce a click whenever a new midi note is sent to the sub37.
update 2
I also noticed the clicks when I use the sub37s arp, i have only one Osc and then turn the all the envelopes to zero, so no sound should come out, but I get the click, it’s very noticeable when I use the sub osc and have the filter turned down. And for the sub osc test I have the envelopes set to just sustain on 100%
I started noticing them (the clicks) when I was sequencing with Ableton.
hi,
did you check the midi in-out settings in Ableton’s midichannel that you use?
I had the same issue and it was caused by a midi loop, because i used the keyboard and arp on the moog and ableton routed the same info back to the sub 37. took me a while to figure out what was happening..
good luck
I will take a look when I get on it today, did you tell the sub37 not to send midi to ableton?
no, but something similarl: i told ableton not to sent midi to the sub37 (during record).
you can also use local on/off i think..
I have tried the midi in/out settings in ableton, and I have tried using usb and midi cables, I do not know if it just the nature of the beast but it can produce unwanted noise when the filter cutoff or amp sustain is low:(
