Does anyone have a suggestion on linking multiple moogerfoogers through midi, being that the moogerfoogers only have midi in? I’m looking to chain the murf and the delay to the sub 37 so they are all locked in time together. But right now I can only use one at a time linked to the sub. Why doesn’t each pedal come with midi in and out ? Dumb question I guess?
One of these would probably work:
http://www.sweetwater.com/store/manufacturer/MIDI_Solutions
Or if you need some routing control of the MIDI signal:
http://www.sweetwater.com/store/detail/MidiExp128
I second the MIDI Solutions Quadra Thru (or similar). Works great, no power needed.
Thanks for your help!
I found this too. I don’t know anything else about it, but it does a 1:6 split.
https://www.tindie.com/products/hotchk155/midisplit-1-input-6-output-midi-splitter/
