midi cc on ableton problem
Hello!
I find that in ableton when i send a linear automation curve to little phatty (like a cc19 for example) i get a sound not smooth at all, it seems like a step filter. I ve tried the same automation on cubase and reaper and all go very smooth and linear.
Someone else has this problem with ableton? There is any solution?
thanks in advance
yes it’s a problem with Ableton. I have looked at LiveMIDI output from automations and it’s not smooth. I’ll talk to my friends at Ableton about it…
really thanks amos. I hope will be a fix soon! because of i can’t get rekon audio editor working on windows 7 (automations causing cpu overload :confused: ) the only solution i ve found is to work with cubase and ableton in rewire
