Is it possible to sequence the phatty via an external sequencer(ie ableton) and use the keyboard as a midi controller? Basically trying to run a sequence from ableton and play ipad animoog as a lead on top.
Yes, set local control off
MASTER → MIDI SETUP → LOCAL CNTRL → OFF
Thanks ill try that, just wasnt sure if there would be conflicts in the input/output Midi messages.
