micromoog & multimoog connections
I have 2 micromoogs and 1 multimoog that I wat to link together (at least the 2 micromoogs ).
What is the best way to connect the 2 micromoogs to get 2 osc+2 subs?.¿Has someone connect both the 3 machines ? ¿ how? Any sugestions?
Also I have an moog DVCO custom engeneering dual oscillators rack . I know that in a minimoog you need to make custom changes to use it with the DVCO ¿ The same with an micromoog & multimoog ? .¿Can I use the DVCO with no mods in my micro? ¿ the way to do this?
I have the complete kit form moog Modusonics to mod my minimoog + the DVCO but I d´ont want to do this as my mini is an collectors condition Musonics with R. A Moog boards. Maybe the best use for this kit will be fitted it in one of my 2 micromoogs.
Any comments will be apreciated.
Thank you
Jan
You need to either make or buy (good luck ive been looking for awhile) s-trigger cable with both male and female plugs. the s-triggers are the ones that kinda look like 2 prong wall outlets. basically take that s-trigger cable and connect it to the s-trig out on the master micromoog and s-trig in on the slave micro. then take a 1/4" patch cable and plug it into the keyboard out of the master micro into the osc in on the slave micro.
as far as connecting all 3…i have no clue, you might be able to daisy chain them or make some sort of splitter device. maybe some of our more technically minded members can help with that
as for the dvco, when i spoke to mike bucki before going MIA he said i would need no modification to work with the dvco with the micro. micro keyboard out to dvco mulitiple, mult to osc 1 and osc 2 in, mixed output to micro audio in. you might need to attenuate the keyboard out on the micro if either of yours have the option. did you buy the dvco direct or used from ebay/craigslist etc?
my recomendation, pair one micro with the dvco, the other with the multimoog, the you have 2 amazingly versitale 3 VCO synths! :open_mouth:
Thank you for your info
Its good to know from you that I can link my DVCO and my micro&multi with no mods. I have an NOS complete KIT to modify my minimoog that I bought some years a go from Mike bucki ( also with the NOS moog DVCO+ all the original docs ). Finally I have not perform this mod as my minimoog is an Musonics in collectors shape.
Currently I am ussing the DVCO with my arp 2600.
About the cables I have ask Kevin Lightner to see if he can make me some.
I will try ASAP to link the DVCO with my multimoog: it must be wonderfull to have an multi with 4 oscillators + 1 sub
Again Thank you for your Help
Regards jan
sounds like you got a pretty nice collection there. yeah 4 osc multimoog would sound amazing, and if you can get the twon micros hooked up to that as well… you might level your house and possibly your city lol :open_mouth:
