Micromoog doepfer dark link connection
Hi
Can anyone give me some pointers about sequencing a micromoog thrue a Doepfler dark link?
Midi connection works.
Bought a cv/gate cable.
Cv1 out to audio in(?)
Should work but it doesn’t.
What can I do to fix it?
Should I check the micromoog inside, if so what should I check?
No, this won’t work, I’d say.
I am not owner of a Micromoog, but according to the service manual you must provide the sequencer CV to the Micromoog EXT. OSC I/P jack and the sequencer gate to the EXT. S-TRIG I/P jack. Please note that most sequencers provide a voltage gate per default which has to be converted to an S-Trigger before. There are converter cables for that. Some sequencers can be configured to provide a V-Gate or S-Trigger.
The Micromoog EXT. AUDIO I/P jack can be used to feed an externel audio signal into the filter section of the Micromoog. But this is for processing of external sound material, not for Micromoog control.
