Micromoog cv/gate midi cotrollers???
Hello forum people, hope everyones good out there…
Any good advice will be greatly appreciated & info on anyone running a midi micromoog setup!!
Thankyou for your time in advance :wink:
Over past few months i have been researching and looking at suitable cv/gate midi converters to control my micromoog.
I have found quite a few different types and options (both mass produced & diy kits etc).
In my research of the mcromoog it has been noted that the cv/gate has a fault rendering it requiring 0.99v to operate properly (instead of the standard 1v per octave), as such these are my questions…
  1. will the micromoog still operate receiving a 1v signal?
  2. will the pitch be affected or will it fall inline with the cv device?
These are the current devices i am considering buying for reference (due to having low funding at present) -
https://www.cykong.com/Synths/Vesta%20Kozo%20MDI-1/VestaKozoMDI-1.htm
https://www.ebay.co.uk/itm/MIDI-CV-Converter-4-channel-Polyphonic-Midimuso-Octex/143633535270?_trkparms=aid%3D111001%26algo%3DREC.SEED%26ao%3D1%26asc%3D20160908105057%26meid%3Db566bc18af664fc1ac66e0c0d1ee779c%26pid%3D100675%26rk%3D2%26rkt%3D12%26mehot%3Dnone%26sd%3D224126642357%26itm%3D143633535270%26pmt%3D0%26noa%3D1%26pg%3D2380057&_trksid=p2380057.c100675.m4236&_trkparms=pageci%3Aff71b5c9-e475-11ea-99d5-74dbd1809e90|parentrq%3A163802991740aa47af4df613ffffcffa|iid%3A1
You should use a MIDI to CV interface that features a way of handling this. Many interfaces are able to adjust their output to match the synth.
This little less than 1 V/oct was done by intention on many Moogs, as it is not easy to boost voltage, but easy to reduce it. In fact, a single resistor will do the job.
Hey thanks for your reply. Ive not come across any controllers so far that make it clear they can alter cv output.
Could u recommend any please?
Pro Solo mk2 and mk3 work fine.
Use the mk2 here.
ok thankyou
Thank you for the helpful thread!
In my studio, I have a Micromoog, a Rogue and a Slim Phatty. So far, I wasn’t able to get them playing in sync using cv/gate (and an Arturia beatstep). I understand, the Rogue and Micro have different standards and the Phatty doesn’t send cv gate. So - is the only way via Midi and dedicated CV/Gate interfaces for the two vintage Moogs?
Thank you,
Martin
