microbrute cv/gate out - minitaur in = out of tune
I just tried to calibrate the 'brute’s pitch CV using an Arturia Beatstep and the sysex messages from this thread and I also ended up with A flats instead of C’s. I’ll go ahead and calibrate it to A flats as LexTron6K did above. I just thought I’d share that in case anyone else is tinkering around with this.
This thread seemed the most relevant, so I am posting my findings here…
I’ve heard from a couple of my semi-pro musician friends that the CV inputs on the Minitaur have issues, and seeing that there was a new firmware out for it, I decided to run some tests on my Minitaur and see if it had the problems they were talking about that prevented them from using the Minitaur in their analog-controlled setups. Up till now, I’ve used my Minitaur, which I’ve had for a few years, from MIDI only and had no real issues, and always gotten a great sound.
I set my MacBook Pro, Minitaur, Keith McMillen QuNexus keyboard (http://www.keithmcmillen.com/products/qunexus/), and electronic tuner up — and I thought you’d be interested to see what I found out:
First, I downloaded the Editor (see previous email) and latest firmware, connected the Minitaur via MIDI, and used the SysEx Librarian to load the latest firmware onto the Minitaur. I ran the tuning calibration tool from the Editor’s settings page.
Then I played every note from MIDI, and tested the Minitaur’s notes to make sure it was in tune. It was, perfectly. Every note was right on the money.
Then I connected the QuNexus keyboard’s analog CV outs (gate and pitch) to the Minitaur. The notes were definitely NOT tracking right at either 1V/octave OR 1.2V/octave (the QuNexus’ Editor gives control over the voltage), even after I reset the Minitaur to “default CV settings.”
So I used the CV calibration tool in the Minitaur Editor, playing C1 and C4 from the QuNexus which sends +1 and +4V into the Minitaur’s CV inputs, and that worked — sort of…. with the following caveats:
  1. The notes didn’t track 100% perfectly. The C at the lowest octave was a little flat, as were some other notes. If I tuned the middle C ( using the manual tuner on the front panel) in the range, I got the best overall tracking, but it wasn’t anywhere near as precise as the MIDI notes. However, it sounded fine to my less-than-pitch-perfect ears played against each other… The notes were off by 10-15 cents at most, and tracking was generally the same from octave to octave, it was within the octave that the notes were off. This might be an issue with either the Minitaur and/or the QuNexus.
  2. For some reason the gate signal that was being sent triggered a note on the Minitaur on BOTH note in and note off. So it plays a second, unwanted note when you release the key. and sending gate to “S-trigger” from the QuNexus didn’t help. I’m not sure what’s up there… anyone have ideas? Maybe it’s the 0-5V versus -5 to 5 V problem?
  3. It wouldn’t let me play notes as low as I can play with MIDI. The calibration asks you to press C1 for +1V and C4 for +4V, but you can’t seem to get a note below C2 to play on the Minitaur — only 2 octaves seem possible. Sometimes even playing the lowest C, it jumps up an extra octave or 2 which doesn’t make sense.
  4. The calibration seems to drift over time, too.
  5. The CV input stops working sometimes when you unplug the USB-MIDI connection to the computer (which I only had in for access to the Editor), which makes no sense at all — although I have since read in another thread that this was an acknowledged issue with CV control.
Summary: It might be usable for a recording where you’re playing one octave or so, but trying to get this working in a live context would probably be a nightmare… and for a studio context the inexactness of the tuning could be frustrating, although it sounds close enough to my ear, the tuner says differently.
For now, I am going to stick with trying to control this thing with MIDI only, which is unfortunate, since has all those CV inputs on the back.
I’d love to hear what others’ experiences with this are, or any tips. And of course if Amos would like to chime in, that would be awesome, too.
Alec
Update to my QuNexus CV attempts: it turns out that turning off the Minitaur and turning it back on changes the pitches all over again — something closer to the A-flat thing that was being talked about above, but it’s not consistent over octaves.
The good news is that you can get the lower notes again, instead of being restricted to one and a half octaves, but it doesn’t even come close to tracking consistently.
Frustrating!
I recently tried getting my minitaur cv inputs to work with my qunexus and a brand new mother-32. Having exactly the same issues chefmenteur described (thanks for documenting it! saved me a bunch of time trying to figure what I was doing wrong).
So I guess the CV inputs are somewhat unusable then? That would be a real shame. Part of the reason I picked up the mother-32 was because it was supposed to be an excellent companion to the minitaur. If anyone knows of any work arounds I would love to hear them. I’d ultimately like to be able to send gate/pitch messages to both the minitaur and mother-32 without having to use a computer. I hope this eventually gets sorted out.
““So I guess the CV inputs are somewhat unusable then? That would be a real shame. Part of the reason I picked up the mother-32 was because it was supposed to be an excellent companion to the minitaur. If anyone knows of any work arounds I would love to hear them. I’d ultimately like to be able to send gate/pitch messages to both the minitaur and mother-32 without having to use a computer. I hope this eventually gets sorted out.””
Howdy esotericmetal, is this something you’re running into if you have the KM QuNexus as part of the chaining? Or do you also see the issue if you bypass the KM Q and just connect cv/gate directly from Minitaur to Mother-32
I have three moms up and was just getting ready to order a Minitaur. How does the Minitaur and Mom sound via Midi?
Thanks in advance for all and any FEEDBACK!!!
The minitaur is only designed to accept 0 to +5v, where as the mother puts out -5 to +5. So only the gate (and the other cv outs that only put out +5) would work correctly even if the minitaur didn’t have the tuning issues.
The qunexus is supposed to put out 0 to +5 so it should be able to work fine with the minitaur if these tuning issues are fixed.
I too am stymied trying to use my Minitaur with CV. Anyone out there managed to get it calibrated and tuned for use with CV?
I signed up to this forum purely to reply to this thread… dedication
YES you can totally calibarate the minitaurs pitch CV ins with those 2 sysex’s Amos shared BUT
YOU HAVE TO SEND G#1 FOR C1 AND G#4 FOR C4 (or A flat :wink: )
I used MIDI OX and it worked a treat, first time using the program and it was done with 5 minutes
The tracking isnt 100.0000% but VERY close, close enough for me anyway
I’ve been fighting a similar battle except with my Korg SQ-1, using a mixture of the techniques in this thread I can get ~3 octaves of decent tracking from the 1V/O linear scale output, after calibrating 1V/4V reference with the built in feature of editor 3.1. I haven’t been able to reliably achieve played notes played over CV, any lower than C2, despite setting 1V reference via C1 or G1#.
I’m glad to see I’m not the only one on the forum with these findings. I also have 2 local friends, both of whom are electronic artists of some reknown, who have also tried with no success to get their Minitaurs to accurately track pitches using the CV inputs. One of them even brought his to Switched On Sound in Austin, and they couldn’t solve it either. I am guessing that fixing this is either impossible due to a hardware issue, or Moog simply don’t have the staff or the time to allocate to this issue, but they may not realize how many people are being affected by this.
