My Minifooger Trem pedal won’t turn off. It’s on right when I plug it in but the power switch won’t shut it off. The pedal works fine except for this issue.
Do you mean the bypass switch? No minifooger has a power switch; the button you step on just bypasses the circuit passing the audio straight through. And by the way, if you have the switch in bypass and you are still plugged into the input, you are drawing power and you will drain your battery. In any case, it is probably a bad switch or relay, so tech support is the right call.
