Hello,
I have recently purchased a Moogerfooger MF-104Z Analog Delay and I love it!
However whilst gigging it recently to my horror I found that the MIx Knob has snapped off leaving the white plastic ‘stem’ stuck half inside of the Moogerfooer and half inside the Knob.
I need to know how to resolve this problem. Can I buy spares - if so where ? and is this easy to replace ? is it just a case of undoing the nut that holds the white plastic stem in place, removing the broken plastic and replacing it with a new knob.
Hope you guys can help,
Cheers
James
http://www.myspace.com/hifictionscience
If you still have warranty i would suggest to send it back to Moog.
Well I can sent it back but it will be fairly expensive to post from the UK to the US and I can do this as a last resort.
Is the Mix pot wired directly into the board of connected with wires ? Just want to know if it’s easy to do my self and if there is no chance of the actual pot or circuit board being damged. If that’s the case I may be able to resolve it myself.
The pots are soldered to the board on the 104Z. If you have some practice, it isn’t hard to DIY. You need a desoldering tool and a good iron.
