My cluster flux has stopped working. When I plug it on, it just lights up with all leds at constant yellow. Just happened from one day to the other. Unless it got jealous because my Minitaur got upgraded with wood panels, nothing else happened.
I have tried using my MF-104M power supply, and the result is the same. I did notice, however, when checking the MF-108M power supply on the delay pedal, that it was faulty: It required a little wriggle before the delay got turned on properly. So obviously, the power supply is not functioning as it should (cord is unstable around the jack).
But none of two well-functioning original Moog 400mA power supplies I have, make the cluster flux work. It just lights up in full yellow. ![]()
Does anyone have an idea what the problem can be? Can the faulty power supply have caused the problem (which I doubt, as I do not move the stuff around at all)?
I am still on warranty. In case it need to go to repairs, does one contact the seller or make an RMA with Moog (I am in Europe)? I would guess most sellers send it to Moog anyway.
Thanks in advance for any response!!
