Hello can you give me some examples to use the Feedback Loop insert Port with other moogerfoogers ( mf102,107 or other)i have an insertcable!
Thank you
One way I’ve used it is setting the delay time multiplier on the cluster flux to x8 (max) and then using the 101 Lowpass filter on the feedback insert to filter out the BBD clock noise and use the 101’s envelope follower to shape the delay.
With the cluster flux set with a high delay time and in chorus mode, and with the delay multiplier - you get a cool/weird lo-fi delay sound.
I used that technique in the track below, which is full of wacky moogerfooger mangling.
