mf-107 whit bass guitar
i was thinking about buying a mf-107 to use whit my bass, but there are no videos on the youtube, or audio samples anywhere. So i was wandering if anyone who has it could make a video using it whit the bass and show some effects and possibilities.
Thanks.
I’ve been working on new stuff and haven’t made any clips in a while, but below I’ll post a couple old ones that have the Freqbox in them-- these were all made in my infancy with the Freqbox and just show some of the more basic and ‘practical’ uses of it.
For use with bass guitar, I find a combination of an analog octaver set to -1oct and 100% wet (no dry signal) and fed into an EQ with the highs cut, pre Freqbox, to significantly aid in tracking, though this requires you to play your lines an octave up the neck to stay in the bass frequencies. If that is not an option or is unwanted, then EQing and/or using a gated fuzz can also stabilize tracking when playing down low on the neck with dry bass guitar signal. I use a Boss OC-2 into a Boss GEB-7 for this application.
This clip uses the Freqbox’s sawtooth into the Lowpass filter, and then the Phaser is kicked using the Lowpass filters Env Out to sweep, and some delay and flange iirc. Something random recorded when I first figured out the Freqbox tracking:
http://soundclick.com/share?songid=7671731
And these are from a jam with a friend, both are just the OC-2->EQ->Freqbox->Lowpass filter:
http://soundclick.com/share?songid=7721411
http://soundclick.com/share?songid=7721396
Thanks for the help man, and your sound is realy cool, like it.
Well if any one else has some sound samples or videos, i still want to see more, thanks
I have made 2 videos that are on youtube.
Freqbox Bassballs Analog Hybrid Synth
and
Freqbox with Rhodes and Bass Guitar
You can find them by going to my youtube channel
youtube.com/rhythmicons
thanks man, very helpfull
