MF-104Z vs MF-104M
Well my initial reaction after spending a cpl hrs with the 104M pretty much echoes (no pun intended) most people here: it’s definately has less of a “clicky” feedback character, more smooth. The fidelity on the short delay setting definately seems a bit crisper. The modulation is fantastic. Just a tiny bit of the random/sample and hold wave shape adds such a great tape echo unpredictable warble to the sound…love it! The 104M seems to “latch on” to quieter playing better than the 104Z. I find at least with my 104Z that if your playing is quiet the signal doesn’t echo much whereas the 104M seems to track dynamic a lot better which in my book is a big plus! The dynamic headroom on both units seem about the same otherwise. The 104Z definately has more delay time than the 104M (unless you use tap tempo)…probably has something to do with the increased fidelity? I find the 104M to be a tad touchier on the feedback as well. My 104Z I really have to crank the feedback to get it to self oscillate…oscillation definately comes on a bit sooner on the 104M…again, a plus in my book. I’ve found the repeats on the 104M to get appreciably grungy, at least for my use. I noticed some folks saying the 104Z is grungier but I haven’t really noticed any huge difference at least with my initial tests. I’m going to use the 104M in place of my 104Z at a gig tomorrow…will report back then!
theyre both great delays, but I think with different uses. The m is more about modulations and midi implementation. I found it difficult to use in some tempos, and was abit more difficult to find a sweet spot. However, if youre not trying to do boring run of the mill delay usage, I found it could do some great mangling.
I prefer the Z, but that is becuase of how I approach my music, and my workflow. That isn tto discount it though, because the M is still awesome.
Well nothing major to report after using the MF-104M in a live setting for the first time other than it worked perfectly. Definately easier to use than the 104Z at a gig due to the tap tempo feature and the fact that, as I previously posted, the echos seem to “latch on” a bit better to softer playing dynamics than the 104Z. I also love having the spillover feature on available via footswitch. I mostly left the pedal in true bypass mode but for a dub reggae song the band did I put it into spillover for the echo trails…very versatile in that regard and easy to do! Plus I bent over and did some modulation tricks with the LFO section at the end of the tune eliciting strange looks from the other bandmembers…lol. You can’t do that with your grandmothers 104Z!! Call me a convert!
Adding my 2 cents…
I have both the 104m and the 104z and I prefer the 104z. The repeats are slightly darker (less high end) and thus it doesn’t compete with your original signal in the mix. The Z does have slightly more noise to it but its hardly noticeable unless you’ve got the drive cranked and your amp volume is up. I put both pedals signals on an oscilloscope and noticed that the phase oscillates with the 104z whereas with the 104m the phase is always positive. I find that I don’t use the tap tempo option to often and the modulation of the repeats on the 104m is nice when subtle but can get unruly at higher amounts. Both are great effect pedals and I will likely keep them both, but the 104Z is my favorite of the two.
Cheers
The 104m has the insert effect for affecting the delay signal only (as the z’s loop in and out). So, with some equalization on the repeats would it not be possible to mimic the 104z sound?
It’s not only a eq issue. The dynamics are different, all in all they are two different pedals, really.
Another thing: the external feedbback loop of the 104Z applies to the second repetition only. I mean: the first echo is not affected. That was a disappointment for me. The 104M does not suffer that.
