ciao
i tried to update firmware 1.1.3 following the instructions
after bootloader mode (3green LED) I can’t erase the current firmware, since the LEVEL LED is not blinking yellow three times. Neither can i send the “Factory_restore” command.
I use a Motu Micro Lite via ELektron Overhub and Sysex Librarian from snoize.com I dont’t have much experience with sysex commands. so I attached the Midi Monitor screenshot.
- i tried with port 5 and port 2 MIDI out of the Motu
- i changed MIDI cables from cheap sssnake to a cordial. (3m, 5-pin)
can you help me out. thanks a lot
INSTRUCTIONS
INSTALLATION
- Power on your MF-104M with both stomp switches held in. You will see a boot-up LED sequence that shows your boot-loader version number (TIME LED blinks, then LEVEL LED blinks a few times). When all the bottom-row LEDs light solid green, you are in boot-loader mode.
- Connect MIDI out from a computer to the MF-104M DIN MIDI input
a. Open the Sysex-sending software of your choice.
b. Send the MF-104M “erase firmware” Sysex command (_Erase_FW_MF104M_Cmd.syx), which is included with this update. You will see
the MF-104M Level LED blink yellow three times while the firmware is erased. When finished, Time, Level, and Bypass LEDs will all light
green again, indicating a return to Bootloader mode. - Send the new firmware (MF104M_Firmware_v1_1_3.syx) using your Sysex sending software. The Level LED will blink while the firmware is being
transmitted. The MF-104M will reboot to normal operating mode when the update is complete. - Send the factory restore file ( _Factory_Restore_MF104M_Cmd.syx) with your Sysex software.
NOTE: Due to changes in this firmware, your new install will require a factory restore, knob calibration, and may require Feedback to be adjusted. 5) Now calibrate your knobs
